| Home > Technical Chat > cam choice , stick with 266 or ph2 with the gt2056 | |||||||
22nd Oct, 2016 at 07:19:58pm
Men, considering fitting the gt2056 over winter .
22nd Oct, 2016 at 08:30:27pm
Intercooler or not ? A good bump in compression would certainly help off boost too 9.85 @ 145mph
22nd Oct, 2016 at 08:36:23pm
What turbo are you running now ? Agree with Stevie, thats a super low compression ratio. How much boost are you planning to run ?
22nd Oct, 2016 at 08:39:37pm
Yes got a nice big intercooler.
Edited by cossierick on 22nd Oct, 2016. |
22nd Oct, 2016 at 09:23:12pm
If you're not after huge power, I'd up the compression, and run the GT20 at 1bar or so. You'll see a decent hike in power without going daft.
23rd Oct, 2016 at 06:52:10am
Phil, whats my easyest way of upping it ?
23rd Oct, 2016 at 07:58:48am
With such a low compression ratio, what about a cam with a wider Lobe Separation Angle such as the MD274 injection cam.
23rd Oct, 2016 at 09:14:29am
before we get too far are you sure on the 7.5:1?
23rd Oct, 2016 at 09:26:30am
23rd Oct, 2016 at 09:28:24am
I dont want to get too involved with stripping the engine, im removing it from the car to alter the drop gears and swap for the gt20.
Edited by cossierick on 23rd Oct, 2016. |
23rd Oct, 2016 at 09:46:04am
fair enough,
23rd Oct, 2016 at 11:58:32am
So to be fair its going to be swap the turbo and just up the boost .
23rd Oct, 2016 at 12:01:36pm
cant argue with that,
23rd Oct, 2016 at 12:09:43pm
Thanks joe
23rd Oct, 2016 at 01:55:14pm
to be honest, I think it would be safer running the lower CR, at 7.5 you'll be hard pushed to run into det problems even at 30 psi. On 28th Aug, 2011 Kean said:
23rd Oct, 2016 at 05:01:55pm
Thanks joe |
