| Home > Help Needed / General Tech Chat > Faulty Lambda sensor ? | |||||||
2nd Nov, 2016 at 06:58:57pm
My car has not been used for some months but it started right up and ran fine today BUT the AFR readings only moved around 14.5 -14.7 even after a good towsing.
2nd Nov, 2016 at 09:02:17pm
you need to replace with the same sensor you have.
33 Posts Member #: 9867 Member |
2nd Nov, 2016 at 09:44:31pm
If it's a innovate AFR gauge (everyone loves innovate at the moment) you can recalibrate it, you're meant to do it every year or so. |
2nd Nov, 2016 at 11:08:30pm
If it's Innovate, probably lucky if it lasts a year lol 9.85 @ 145mph
174 Posts Member #: 9128 Advanced Member |
3rd Nov, 2016 at 12:15:44am
On 2nd Nov, 2016 stevieturbo said:
If it's Innovate, probably lucky if it lasts a year lol More like lucky you got it working…... |
3rd Nov, 2016 at 04:14:48am
The gauge is an AEM and it has lasted )so far) over 5 years and nearly 17000 miles.
3rd Nov, 2016 at 06:06:47am
The only real way to tell if it the LSU (the sensor) or the controller (the electronics that work the sensor) or the gauge itself is to plug a known working LSU in.
Edited by Rod S on 3rd Nov, 2016. Schrödinger's cat - so which one am I ??? |
3rd Nov, 2016 at 08:38:25am
Thanks Rod. Your usual incisive and complete explanation.
