| Home > Help Needed / General Tech Chat > Oil drain not low enough | |||||||
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
27th Nov, 2016 at 10:39:12am
Well, my Mini is run in now, but I have 2 problems - oil leak from turbo oil drain somewhere even parked up, and the exhaust oil smoke which was getting better is now worse than ever!
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
27th Nov, 2016 at 11:25:29am
On mine I had breather issues that caused smoke. It turned out that my little filter on the catch can had become saturated with oil and would hold just enough pressure to make it smoke. A baffled catch can and rerouted breather setup has solved it.
27th Nov, 2016 at 12:15:52pm
On 27th Nov, 2016 ian2000t said:
- return point is too high for the turbo. Our home made manifold seems to sit the turbo slightly too low to return to the fuel pump blank without it going slightly uphill. this could well be the entire problem, Yes i moved to the darkside |
27th Nov, 2016 at 01:22:56pm
I don't think there's anywhere else you can fit it without disassembling the engine now, I would have a good look at seeing if you can improve the oil return, failing that, it would be modify the turbo manifolds, less hassle than removing, dissassembling, modifying, reassembling and reinstalling the engine and gearbox.
Edited by Carlzilla on 27th Nov, 2016. On 26th Jan, 2012 Tom Fenton said:
27th Nov, 2016 at 03:25:10pm
As much as I would rather not remove the engine, I'm not scared to.
27th Nov, 2016 at 08:29:21pm
Simple question..does the turbo have a good, free flowing gravity drain ?
29th Nov, 2016 at 09:04:52pm
Well, it should be able to drain by gravity OK, it is downhill and it's a good size - 19mm. But, it does kink up slightly which would at least hold oil overnight.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
29th Nov, 2016 at 09:55:03pm
On 29th Nov, 2016 ian2000t said:
Well, it should be able to drain by gravity OK, it is downhill and it's a good size - 19mm. But, it does kink up slightly which would at least hold oil overnight. I'll check the breathers first, might help. Had anyone made a breather out of the dizzy blank plug? My breather system returns to dizzy 'ole On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
30th Nov, 2016 at 09:22:46am
I returned my oil to the Speedo Drive hole when I ran a side mount and it never gave me any issues. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Nov, 2016 at 11:45:05am
Speedo drive could possibly be done with engine left in too. In the 13's at last!.. Just |
30th Nov, 2016 at 12:42:02pm
Well, it should be able to drain by gravity OK, it is downhill and it's a good size - 19mm. But, it does kink up slightly which would at least hold oil overnight. I'll check the breathers first, might help. Had anyone made a breather out of the dizzy blank plug? My breather system returns to dizzy 'ole Do you have any pictures of how you did it? 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
30th Nov, 2016 at 12:44:03pm
On 30th Nov, 2016 theoneeyedlizard said:
Speedo drive could possibly be done with engine left in too. Not a bad idea. Would you just use an electronic speed sensor then instead? 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
30th Nov, 2016 at 06:02:32pm
U can see it in my thread on first page if ya look close... but its as simple as catch can bolted to drivers brace bar, return to dizzy hole, and other to rocker cover and one to just below of intake filter On 24th Oct, 2015 jonny f said:
16th Dec, 2016 at 02:01:51pm
Quick update:
16th Dec, 2016 at 04:26:30pm
20th Dec, 2016 at 01:24:14pm
Oil pressure is 20psi at idle hot; 40psi at 2000rpm+ hot.
