| Home > Help Needed / General Tech Chat > Starter modifications | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
19th Dec, 2016 at 09:11:44pm
Hi has any one modified a pre engaged starter to move the solenoid as it's right in the way I've looked at the slimline & high torque but there quite expensive and iam a tight git 😂 |
19th Dec, 2016 at 10:10:30pm
I modded mine on the metro but can't recall what i did off hand |
19th Dec, 2016 at 11:28:20pm
I'm pretty sure Matty modified his starter as you describe Scott.
20th Dec, 2016 at 06:56:05am
Cheers guys I have a look when I get some time at what I can do I take some pics so if it works i can put a how to on for anyone else wanting to do the same I just can't justify 225quid without at least trying to modify first |
20th Dec, 2016 at 07:14:04am
The mini / metro starters ... same starter different solenoid position
Yes i moved to the darkside |
20th Dec, 2016 at 07:20:36am
http://www.turbominis.co.uk/forums/index.p...d=466344&fr=100
20th Dec, 2016 at 08:32:04am
The mini solenoid is at around 10o'clock whereas the metro one is around 9 o'clock if i recall
On 20th Dec, 2016 Brett said:
The mini / metro starters ... same starter different solenoid position I forget which is which but one helps with space around the front You can also re drill and rotate the starter so the solenoid is tucked up to the engine block There may be pictured early on in my built thread If not search a members build thread ..benny.. Without the ....s I did it in his engine too |
20th Dec, 2016 at 07:51:07pm
I had a look earlier when I had to pop to the unit to get some work stuff the mini one is further round like you said Rob which mite just give me enough room to get me fan in as I only need an extra 10mm I think |
20th Dec, 2016 at 08:02:34pm
I'm pretty sure I followed either Brett's or Matty's details anyway |
