Home > Help Needed / General Tech Chat > Pre verto on short arm/cable
Dangerous
Member #: 417
Any ideas on putting a pre verto in a metty turbo as its on a cable clutch and the servo is in the way to change to hydraulic*oh well*
just put the longer arm on and move the cable?
Im guessing you've thought of that though...
I've used a pre verto flywheel with a cable in a metty, you end up with a short stiff stroke tho! and I only used a std pressure plate, I was a bit wary about the cable breaking.
Dangerous
Member #: 417
If the slave cylinders are the same diameter I guess I could use the long arm then *oh well*
