Home > Help Needed / General Tech Chat > t2 actuator options
dave-88_123
Member #: 5754
Bridport Dorset
What actuators are people using I have a Collins actuator with a forge spring fitted would this be any good
anything that fits will be fine,
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I used a Colin's -31, it had a long rod that I was able to cut down to suit the actuator mount. I didn't get anything higher than about 12 psi on the standard spring, different rate springs are hard to find so I've used an electron boost controller. The EBC is highly recommended! Nice stable boost and you can change boost from high to low on the fly.
On 7th Nov, 2008 Nic said:
naeJ
m
