| Home > Help Needed / General Tech Chat > All I want is a tight box and good head! | |||||||
42 Posts Member #: 10317 Member Basildon, Essex |
5th Jan, 2017 at 09:38:23am
Hello chaps,
Edited by Skortchio on 5th Jan, 2017. |
5th Jan, 2017 at 09:40:16am
GT17 and Megajolt.
167 Posts Member #: 11091 Advanced Member |
5th Jan, 2017 at 10:10:16am
On 5th Jan, 2017 Tom Fenton said:
GT17 and Megajolt. Why megajolt over nodiz? (Thought it was pretty much copied with some extras chucked in?) |
5th Jan, 2017 at 10:23:20am
Might not have been concise enough, all is done bar the head and box.
GT17 and Megajolt. |
5th Jan, 2017 at 10:24:35am
If you don't need to remove the beak in the chamber to get the volume, then don't. Just modify the chamber as you would for performance NA use, and to the size you require.
5th Jan, 2017 at 10:30:28am
On 5th Jan, 2017 Skortchio said:
Might not have been concise enough, all is done bar the head and box. Gt15 shouldn't have trouble hitting the mark unless I've totally misread the map and calcs? On 5th Jan, 2017 Tom Fenton said: GT17 and Megajolt. The biggest issue for the GT1549 is the highly restrictive turbine built for slow speed small diesels. It will spool up quick but then hit your torque hard before you hit the rev limit. Depends what you want. Same goes for any of the GT15s with the exception of the GT1548, but that is a bit small on the compressor side for a 1275. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5th Jan, 2017 at 10:33:28am
Revving out isn't a concern, the build isn't for redlining as it's not her thing. Solid midrange, road based fun, traffic light gp and tons of punch out of corners. |
5th Jan, 2017 at 10:41:44am
keep beaks , 8.8:1 fine , leave head stock ,use a soft 250 ish degree cam , or stock cam .big intercooler . see what happens. try with helical . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Jan, 2017 at 10:43:00am
If you don't want to spend a lot on head work, some simple valve and seat work and modifying the chamber as mentioned will yield some decent flow gains.
5th Jan, 2017 at 10:44:26am
Ah pap knew I forgot something, 266 cam is fitted. |
5th Jan, 2017 at 12:07:41pm
Biggest problem with the Sc gears is that the ratios are too close for road really. Running a tall diff ratio for cruising on the road hurts your pulling away which is obviously important I'm a road car too.
5th Jan, 2017 at 12:48:39pm
if your going to run highish compression ratio, with a piston change you can probably run a decent 2nd hand ported NA head.
6th Jan, 2017 at 02:17:57pm
Thanks for the input, chaps.
6th Jan, 2017 at 03:10:02pm
Is the head the stock 33mm inlet valve one ?
6th Jan, 2017 at 04:54:32pm
It's a stock Metty turbo head, so I would assume just the larger stems on exhaust.
