Home > General Chat > Yay - Found a decent Rolling Road (operator) nearby!
Only 42 miles from me!
http://www.ayaracing.com/index.html
Check this page out for some pics, and click on the dragster picture!!!!
http://www.ayaracing.com/dynoday.html
I found out about them from a fella with a 9-second (80's generation) mustang, running a turbocharged pinto engine, whilst at the drag strip on Friday (I was doing more v8 muscle car killing - but only running 13.9's *frown*)
Edited by turbodave16v on 20th Sep, 2005.
dan
Member #: 93
great stuff!
i take it you'll be paying a visit even if its to check out what they experience is of the a-series is?
On 20/09/2005 20:00:36 dan said:
great stuff!
I think I can already guess at their A-series experience!!! *laughing*
dave whats there reaction when you blow them away with the mini
i bet your the star of every event you go to
so you got everything you need now!, what octane fuel can you get over there?
T3Tone
Member #: 252
Sunny suffolk
Good to hear Dave.
Whats your best 1/4 over there so far?? 13.9 is still very respectible imo.
-MINI CLUBMAN 1380 TURBO-
13.9 on the same damaged turbo i've been tunning for the past year (16psi max boost, even when disconencting the actuator hose)...
Hopefully, when i strip the lot down over winter, I'll find the turbine housing is indeed damaged. This will hopefully also mean 'more' power everywhere, as the turbine is clearly by-passing a lot of usefull gasses straight through the wastegate...
Oh, regarding fuel, the calorific value appears to be pretty similar, but the knock resistance is a lot more, which basically means there might be potential for playing with the ignition timing - but this won't neccesarilly give any more power*oh well*
Ben - It gets a lot of attention, as you can imagine.
Edited by turbodave16v on 21st Sep, 2005.
cool will it fit little mini on there LOL
