Home > Help Needed / General Tech Chat > Fuel pipe where to get from?
steve2016
Member #: 11403
I have some 8mm micro bore pipe sorted from screwfix £15 for 10m but now need some hose. Which hose / where do you recommend purchasing it from? I have read some hose is of poor quality and can split easy which I don't want happening...
Is it OK to use the 8mm for the return as well?
Thanks
evad1980
Member #: 10165
Stansted, Essex
I just got some from a local motor factors.. 8mm ID proper fuel hose, about £6 per metre.. Ive done the same as you but got my pipe from plumb city.. 8mm for both feed and return.
Yep Local Motorfactors
steve2016
Member #: 11403
Thanks will call my locals. What about halfords has anyone used there's?
Also will this fuel filter be OK to use?
http://m.ebay.co.uk/itm/UNIVERSAL-Chrome-G...0%257Ciid%253A1
Thanks
steve2016
Member #: 11403
Halfords with the trade card £3.20 per meter off the shelf with 2x free fuel hose clips
Be carefull Local Motorfactors sold me a load of shite, never even got me off the drive before splitting and dumping a few litres of fuel all over my engine
steve2016
Member #: 11403
Been reading into fuel pipe and apparently fuel now has stuff added and it rots some fuel pipe types...
Something about high quality r9 rated pipe is what we need to use now due to ethanol being added to fuel and even that sometimes isn't 100% resistant to it... Your can get 100% resistant pipe but it was something like £15 per m
I'm currently replacing all the hose I fitted to my car less than 4 years ago as it is starting to perish (one hose split highlighting it); bought cheap from the local factor. Happily spend the right money for peace of mind
Proper stuff should have writing down the side stating its usage and size.
Ive had some fuel pipe from my local motor factors which has been on 3 cars now with no issues :)
mine had all the correct markings; still shit
steve2016
Member #: 11403
I first noticed bad quality fuel pipe when i went to pull the carb inlet pipe off and it just tore off in my hand... Wasn't that old either.
Read a thread on piston heads where someone went to start his s3 and fuel started squirting out everywhere....
One of the threads linked me to this pipe
http://m.ebay.co.uk/itm/7-6mm-5-16-R9-FUEL...4%257Ciid%253A1
Buy Gates, or similar reputable brand that is intended for the application in mind. Job done.
Most local factors should stock such things...if they dont, they're crap lol
Streetscreamer
Member #: 10125
Zoetermeer, The Netherlands
Braided PTFE lines only for me.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I used the micro bore pipe for feed and return. I find if the car sits for a few months without being started (over the winter), when I first start it the carb floods like crazy, I think the ethanol content causes some corrosion in the fuel pipe which then jams the needle in the fuel bowl. It never did that when I used proper fuel hose.
On 7th Nov, 2008 Nic said:
naeJ
m
