| Home > Help Needed / General Tech Chat > Slow clutch!? | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
21st Jan, 2017 at 04:08:43pm
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
21st Jan, 2017 at 07:41:03pm
hose swollen inside . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
21st Jan, 2017 at 08:43:15pm
yeah could be the hose if its a standard one, or Ive had the seal in the master go squiffy before so the pedal sticks, it actually used to sort it self out with a few pumps so was wondering if the sea; can flip inside out of somthing.
21st Jan, 2017 at 10:03:31pm
Robert and joe.. i have had both problems before with brake parts instead on another mini so i definitely can see where your coming from...
21st Jan, 2017 at 11:57:03pm
I had this on one of mine and it turned out the yolk has partially seized from sitting |
22nd Jan, 2017 at 11:18:29am
i agree with Robe
22nd Jan, 2017 at 12:34:50pm
22nd Jan, 2017 at 03:51:34pm
Plus 3, really common on a car little used. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jan, 2017 at 06:48:28pm
Wellllll thanks for all the replys guys but Robert gets the brownie points!! Had a look thru everything and the hose had a bulge just under where it bolts to the bulkhead.. swapped that over and its perfect! So the force of the pedal would push fluid one way but the crapped out hose wouldnt let it return fast enough to let it pull away which really does make sense with my original post as quick pumps kept pushing fluid thru n only returning a small amount back until it was maxxed out and the pedal went hard then leaving it 5 seconds was enough for the fluid to return... it was like the title says a slow clutch/ someone riding the clutch?
22nd Jan, 2017 at 06:50:46pm
Good stuff,
22nd Jan, 2017 at 06:53:56pm
Indeed joe my front drivers side brake flexi did that on london2brighton a few years back now, it is the best advert for braided, i shall look for the one piece u speak of now... On 24th Oct, 2015 jonny f said:
22nd Jan, 2017 at 07:06:21pm
http://minispares.com/product/Classic/Clut...k%20to%20search
22nd Jan, 2017 at 08:18:26pm
23rd Jan, 2017 at 10:11:57am
Whilst you are thinking about it, lubricate the plunger in the wok! As said they can seize in place. Just go steady with a little oil as you don't want it finding its way onto the clutch.
