| Home > Help Needed / General Tech Chat > What actavator do I need for 7psi | |||||||
2 Posts Member #: 11518 Junior Member |
9th Feb, 2017 at 08:28:57am
I need a new actavator for a standard metro turbo that I've put in my mini , what options do I have ? |
9th Feb, 2017 at 10:47:44am
Standard 'actuator' is around 4psi. You can just use a bleed valve to increase to 7psi. In the 13's at last!.. Just |
9th Feb, 2017 at 01:39:42pm
As above. If you've already got the standard actuator just fit a cheap bleed valve, this will also give you the option to go higher if needed.
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
9th Feb, 2017 at 08:41:02pm
Can't a standard one be adjusted to 7psi by increasing the actuator spring rate (shortening the rod)?
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
9th Feb, 2017 at 09:11:19pm
Need a new one as old one is broke |
9th Feb, 2017 at 10:04:11pm
On 9th Feb, 2017 ian2000t said:
Can't a standard one be adjusted to 7psi by increasing the actuator spring rate (shortening the rod)? Good call. It's so long since I've used the standard one. Does anybody know what the standard actuator will give, if much, with more preload on it ? Phil. |
9th Feb, 2017 at 10:31:30pm
I think the same actuator was used on the Escort RS turbo and early Sierra Cosworths, so it must be good for 7 psi without trouble. |
9th Feb, 2017 at 11:23:40pm
I'm pretty sure they have a 10psi version as standard. It was an easy way for more boost as they could be picked up for peanuts.
