| Home > Help Needed / General Tech Chat > Megajolt gurus. Have spark, have fuel, no bang? | |||||||
![]() 118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
12th Feb, 2017 at 10:54:00pm
As above, currently checking timing but seems to be ok.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
12th Feb, 2017 at 11:03:34pm
Was it running previously or first attempt? |
12th Feb, 2017 at 11:30:27pm
I had to play about with the lead order on mine; can't recall off the top of my head what I did though
12th Feb, 2017 at 11:34:33pm
Has it ever run, or is it a new build ?
13th Feb, 2017 at 02:43:10am
Fresh engine build, may have to play around with leads.
13th Feb, 2017 at 08:44:07am
Checked the timing with a light? If something is worth doing, it's worth doing half of. |
13th Feb, 2017 at 09:07:07am
Is there a huge air leak on the inlet manifold and carb (Like evad1980's car) letting in so much air that it won't start.
In the 13's at last!.. Just |
13th Feb, 2017 at 09:35:49am
if its never ran, swap leads 1&4 with leads 2&3 turbo 16v k-series 11.9@118.9 :)
13th Feb, 2017 at 11:00:29am
I would say lead order if it's not run as above.
13th Feb, 2017 at 11:31:52am
So it's getting late here, just went down to fettle, swapped 1+4 and 2 with 3, a couple of backfire pops. PROGRESS!
13th Feb, 2017 at 11:43:33am
Leads from the coil pack should be 1:1 2:2 3:3 4:4 so you don't plug them in like a dizzy i.e. the firing order of the engine as it's wasted spark two will fire at the same time.
13th Feb, 2017 at 11:44:09am
Also check your sensor gap. I run a supercharger and I don't care the TB is on the wrong side.
13th Feb, 2017 at 12:57:40pm
Check air leaks. Easy Start in Carb 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
13th Feb, 2017 at 01:00:18pm
On 13th Feb, 2017 mattsmadmini said:
So it's getting late here, just went down to fettle, swapped 1+4 and 2 with 3, a couple of backfire pops. PROGRESS! Will wait until morning and do another swap and play around! Almost almost! you misunderstood. swap leads 1 and 4 with leads 2 and 3. if you swapped 1 with 4 and 2 with 3 and now its backfireing you have 100% got the leads on that coil wrong, as its wasted spark you should be able to swap 1 with 4 and 2 with 3 with no change atall. turbo 16v k-series 11.9@118.9 :)
14th Feb, 2017 at 01:12:37pm
https://www.youtube.com/watch?v=JSQgNOgc8S0&feature=youtu.be
Edited by mattsmadmini on 14th Feb, 2017. “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
108 Posts Member #: 9182 Advanced Member |
14th Feb, 2017 at 04:39:27pm
I agree with evolution.
14th Feb, 2017 at 10:56:56pm
those sandals and toes again On 26th Oct, 2004 TurboDave16v said:
5th Oct, 2018 at 02:08:44pm
Been sitting for a while and just started another thread, d'oh.
174 Posts Member #: 9128 Advanced Member |
6th Oct, 2018 at 10:14:33am
I know it sounds simple, but check the battery. If it's not got less 12 volts it won't start. |
