Home > Help Needed / General Tech Chat > Diameter of 10" wheel and tyre.
I need a reasonably accurate measurement of the diameter of a 10" wheel fitted with a 165/70 tyre. If anybody can help. I know it will vary a little with rim width and tyre brand, but somewhere near should do.
Phil.
Edited by Turbo Phil on 14th Feb, 2017.
I can have a look once I'm at the garage if you've not had an answer beforehand
Cheers mate.
Simple maths says it's 485mm diameter
10" wheel =254mm
Tyre section width =165
Tyre profile height is 70%
254+(165*1.4) =485mm
Rolling radius is slightly different. Without measuring rolling radius, I assume 3mm deflection, which can mean a fair bit different over a mile.
Phil.
"Reasonably accurate" and "somewhere near" are not the same thing Phil *hehe!*
Callum
Member #: 10396
Stoke-on-Trent
Reverse rim with goodyear rally special 489mm
Minilite copy with falken 482mm
Very helpful. Cheers chaps.
Phil.
graemec
Member #: 1424
Carnforth, Lancs
All on 10x5 GB's:
Yoko A-008 with 5mm tread - 489mm dia
Avon CR6ZZ with 6mm tread - 490mm dia
Avon CR6ZZ with 6mm tread, inflated to 26psi and fitted to front - 235mm from floor to centre of CV nose
Edited by graemec on 15th Feb, 2017.
Cheers chaps, just what I needed.
Phil.
Rammie2000
Member #: 10190
belgium
1.4 is 40%?? should be 1.7 if 70%
10" wheel =254mm
Rammie2000
Member #: 10190
belgium
Maifrini Mille Miglia ( 5*10) with oval tyres ( american stuf 492 mm at 3 bar
Maifrini Mille Miglia with dunlop 490 at 3 bar
momo 5*10 with falken tyres 485 at 3 bar
No, Colin is correct.
70% is 0.7 so it's section width X 0.7 but you have to add it to the diameter twice as the tyre is each side of the wheel diameter. So it's easiest just to say section width x 1.4 plus the wheel diameter.
10" wheel =254mm
70% is 0.7. 0.7 x 2 = 1.4 which is 140% or 2 x 70% *smiley*
3 bar is a lot for a mini tyre........
Rammie2000
Member #: 10190
belgium
Usually around 1.8 at rear and 2.2 at front but its for winter storage. My grandfather always raised pressure in winter and i took that habit with me.
