| Home > Help Needed / General Tech Chat > small leaking newly buid engine | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
18th Feb, 2017 at 11:29:44am
i filled up my newly build 1100 na engine on the traveller a while ago but now filled it up with cooling water for the first time. overnight it seemed to have a leak. ( only a drip over something about 12 hours) it has not run yet but would it be something to worry about? you can do anything if you set your mind to it...
18th Feb, 2017 at 11:31:33am
18th Feb, 2017 at 11:41:36am
o don't look at the screwdriver underneath that isnt water but old paint.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
18th Feb, 2017 at 11:48:40am
Have you traced back where it comes from?
Dazed and Confused.... |
18th Feb, 2017 at 12:59:46pm
Yes head gasket on the corner left under the sender you can do anything if you set your mind to it...
18th Feb, 2017 at 06:38:52pm
Has it been run and re-torqued? |
18th Feb, 2017 at 08:21:44pm
Not yet. you can do anything if you set your mind to it...
18th Feb, 2017 at 08:40:13pm
Is it 11 stud? Leaking out via the extra stud where tapped into the water jacket? On 7th Oct, 2010 5haneJ said:
18th Feb, 2017 at 10:47:41pm
I always run them without any water first just for a minute.
18th Feb, 2017 at 11:39:56pm
So water out then. you can do anything if you set your mind to it...
18th Feb, 2017 at 11:40:49pm
On 18th Feb, 2017 minimole23 said:
Is it 11 stud? Leaking out via the extra stud where tapped into the water jacket? you can do anything if you set your mind to it...
