Home > Help Needed / General Tech Chat > Rebuilding caliper
Yo-Han
Member #: 3228
North of the Netherlands
Guys, is there a trick to fitting the dustseals (metal clip) in a S caliper?
I am really struggeling to get them to fit in.
I've tried tapping round but they just seem to big.
I've now put the rings in the freezer to see if they shrink a bit, but before I bugger them up even more I thought I'd see if there is any advice on here...
Thx
Dazed and Confused....
DILLIGAF
Member #: 9128
You trying to do it with the calliper still in one piece ?
If so stop messing about and split the calliper.
graemec
Member #: 1424
Carnforth, Lancs
I always split the caliper and then press the dust seal into place by putting the caliper half between two squares of 1" thick hardwood in a vice.
They tend to go in with a painful sounding crunch!
Yo-Han
Member #: 3228
Should have mentioned the caliper is apart, cleaned, plated and painted.
Graemec, I guess you do this before positioning the piston in?
(I followed the instruction and did oilseal, piston, dust ring)
graemec
Member #: 1424
Carnforth, Lancs
No - usual order -> piston seals, piston, dust seal.
Leave the piston slightly proud, fit the dust seal to it and then press it all home.
tadge44
Member #: 2500
Buckinghamshire
In my experience many aftermarket caliper repair kits have dust seals that are VERY difficult to fit
Yo-Han
Member #: 3228
Done!
Patience and perseverance win over brute force and ignorance.
Thanks chaps
A bit late now, but in the past I found going round the top of the bore with a hand held de burring tool to slightly chamfer the top edge helped a lot to get the retaining rings started into the bore.
Yo-Han
Member #: 3228
Good to mention for future reference and searches Tom.
I thought of this but since the pistons were already in I didn't do this.
I would deffinately recommend this.
