Home > Non-Mini Discussion > Cleaning Windscreens
It makes me feel very old and sad to post this, but does anyone have any advice for cleaning windscreens as no matter what I do mine smears and streaks when I use the wipers. I'm pretty sure it's not the wipers or screen itself as they are both less than one year / 10K miles old, so I'm guessing that the screen wash is leaving a thin film of residue on my windscreen. So any tips for cleaning it and any recommendations as to choice of screen wash? I shall go now before I start discussing the relative merits of pencils vs pens when writing do diesel locomotive numbers or why the Austin Allegro was the best car ever made.
The best screenwash i have used is sonax, it's not cheap but has a high dilution ratio, also probably best getting a glass polish to get rid of the crap off the windscreen, and also using a good glass sealant such as h2go or soft99 glaco will really really help, don't bother using rainx as it's absolutely wank in comparison.
Sonax screenwash
http://www.ebay.co.uk/itm/112053493144
H2GO
http://www.ebay.co.uk/itm/122130698632
evolotion
Member #: 83
Glasgow, Scotland
wipe your wipers down with a rag and brake cleaner just incase they are contaminated.
Denis O'Brien.
Are you sure it isn't the wipers, I had a similar issue with my BMW, I discounted the wipers as they were less than 6 month old BOSCH blades.
To cut a long story short after trying all sorts of potions and lotions and cleaning this that and the other I bought a replacement set of Valeo blades and straightaway my wipers were excellent.
In my head BOSCH are a quality brand and so as such I discounted that it could possibly be the blades for a long time.
Junked them and sorted.
I broke in my clay mitt on the windows on my other half's car and suddenly the wipers were great...
yeah worth swapping the blades, bit of oil or derv from following a lorry and it can absorb into the blades...
Kean
Member #: 341
aka T2clubby
South Staffs
Rainex. They do a water repellant cleaner which is excellent
mw3
Member #: 9590
Derby
I go over my window screen with a razor blade gets all the gunk off quite easily
Then use this stuff
https://www.trackonedetailing.co.uk/product...epellent-643ml/
Matt W
On 14th Mar, 2012 mw3 said:
PhilR
Member #: 10034
Birmingham
£2 clay bar off ebay made a big difference to mine.
Thanks for all the advice, I clayed the windscreen and swapped the blades for some Valeo ones. Then this morning I was greater by dull drizzly weather, prime smearing conditions and I'm delighted to say that my windscreen stayed nice and clear, problem sorted.
gdouglas
Member #: 11577
+1 on using a clay bar to remove contaminants from the surface. There are also glass polishing kits like Lake Country that you can use.
