Page: |
Home > Help Needed / General Tech Chat > bk 450 gaskets blowing at opposite ends of the head? | |||||||
7262 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
26th Apr, 2017 at 09:36:32am
Because you could be hiding an underlying issue with CR or timing causing detonation. If you then fit a possibly more robust cometic gasket, you'll then start melting pistons instead of popping gaskets.
In the 13's at last!.. Just |
26th Apr, 2017 at 11:25:45am
Has anybody actually had success using a copper gasket with a boosted A series? I seem to recall them not being up to the job when tried in the past. |
4620 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
26th Apr, 2017 at 11:47:03am
Most folk don't have any issue with the BK450. Unless you've had one of the dodgy batch, it's not a gasket issue.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
26th Apr, 2017 at 06:27:24pm
If Jimster is throwing 30psi down its neck at 260+ hp on a BK450 with extra holes punched in to it, there is not much wrong with the gasket really ! On 26th Oct, 2004 TurboDave16v said:
1750 Posts Member #: 10190 Post Whore belgium |
26th Apr, 2017 at 09:38:44pm
oil on the gasket? i tought it needed to be as dry and clean as possible ( sorry to hack the post) you can do anything if you set your mind to it...
9311 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
26th Apr, 2017 at 10:11:38pm
I don't think the BK450 is your issue.
27th Apr, 2017 at 07:29:14am
To answer the question about other gaskets. I use the AF460 gasket on mine (because the center fillet on the BK450 damages my alloy head).
Edited by wil_h on 27th Apr, 2017. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
6743 Posts Member #: 828 Post Whore uranus |
27th Apr, 2017 at 07:36:00am
i only use 9 studs seems to work though Edited by robert on 27th Apr, 2017. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
38 Posts Member #: 11095 Member mold north wales |
27th Apr, 2017 at 07:54:34am
Ok I hear the voices loud and clear may be I am not cut out to build a turbo motor even if it is to standard spec, if all else fails I will have to go back to N/A
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
27th Apr, 2017 at 07:58:12am
On 27th Apr, 2017 cooperman1275 said:
Ok I hear the voices loud and clear may be I am not cut out to build a turbo motor even if it is to standard spec, if all else fails I will have to go back to N/A cheers Roy Why? People have told you what to check. Get on and get them checked. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
27th Apr, 2017 at 09:40:20am
AP I get what your saying mate but I have been pissing about with problem after problem building this car particularly with the engine /box/tunning its fought me all the way to the dyno.
6729 Posts Member #: 618 Post Whore Glasgow |
27th Apr, 2017 at 11:09:45am
don't give up! think of the sense of achievement when you work it out and get it sorted. Took me a while to sort out niggles with mine (and a 15yr build!) but would struggle with an NA engine now.
27th Apr, 2017 at 11:36:49am
Thanks Rob
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
27th Apr, 2017 at 12:56:32pm
It shall all be worth it once this niggle is sorted! Believe me! And since mines been off the road after its crash a year ago ive been running around in a n/a mini n as much as i love that one HELL do i miss boost!! On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
27th Apr, 2017 at 05:24:07pm
My car took 7 years and has done 60 miles in the 2 years since. On 11th Feb, 2015 robert said:
2500 Posts Member #: 648 Post Whore Northern Ireland (ex AUS) |
27th Apr, 2017 at 05:48:13pm
I'm glad I'm not the only one, I've done 300 miles in 3 years...
On 27th Apr, 2017 apbellamy said:
My car took 7 years and has done 60 miles in the 2 years since. On 7th Nov, 2008 Nic said:
27th Apr, 2017 at 09:09:48pm
i'm very similar Jay. First year cost me £2/ mile just in tax and insurance |
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
27th Apr, 2017 at 11:42:55pm
Mate, have a look of my build page to see how much crap I went through, and it all came down to the CR being out.
28th Apr, 2017 at 07:37:08am
Guys
28th Apr, 2017 at 08:17:59am
I think we need to get you a drive in a turbo car then. That should give you a bit of encouragement!
28th Apr, 2017 at 08:38:03am
On 28th Apr, 2017 Rob Gavin said:
I think we need to get you a drive in a turbo car then. That should give you a bit of encouragement! we'd need to see some pictures of his sister first though. On 11th Feb, 2015 robert said:
29th Apr, 2017 at 05:38:56pm
I've not really seen past half throttle, with a run-in map in the ECU and on medium boost but 5 minutes of driving that was enough to spur me to fight on! On 7th Nov, 2008 Nic said:
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
30th Apr, 2017 at 06:25:34am
Through my ignorance and with the help and encouragement of many people on here I took almost two years to get my turbo running right. In that time I blew one piston, one gearbox and a diff,snapped a timing chain as well as setting the car on fire briefly.
11th Jun, 2017 at 05:57:35pm
Well since fitting a cometic gasket and a set of ARP head studs the car is running perfect no issues
11th Jun, 2017 at 10:20:16pm
Glad got a solution |
Page: |
