| Home > Help Needed / General Tech Chat > AEM wideband interrrence problems | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
1st May, 2017 at 05:54:07pm
1st May, 2017 at 06:06:35pm
Is the sensor cable running close to your crank sensor wiring? Is your crank sensor wire screened, and is the screen grounded at one end? |
1st May, 2017 at 06:20:38pm
On 1st May, 2017 metroturbo said:
Is the sensor cable running close to your crank sensor wiring? Is your crank sensor wire screened, and is the screen grounded at one end? nope the afr isnt next to it at all, i even ran the guage outide of the car and still had the same problem :/ the sheilded wire is grounded through the ecu |
1st May, 2017 at 06:28:42pm
check the grounds, try seperating them if they are joined.
1st May, 2017 at 06:44:38pm
i gave it its own earth and its still the same :/ ecu has its own earth too, how far apart do the earths need to be? can the signals travel through the bulkhead very far? |
1st May, 2017 at 08:12:14pm
hmmmm,
1st May, 2017 at 08:34:57pm
On 1st May, 2017 Joe C said:
hmmmm, I would check what the voltage is that it being fed to the ECU from the gauge, it should track with the AFR value, down around 1v at 10:1 about 2.5v at 14.5:1 and near 5v at 20:1. I suspect the lambda heater current is getting into he ECU some how, i belive the heters are normally feed with a PWM current, so could trigger the crank input of the ECU. the ecu and the arf arnt linked together at all, just share an earth at opposite ends of the bulkhead :/ i have been in touch with AEM and this was their reply First thought would be a wiring problem. You might have a sensor ground or timing input ground shared with the gauge ground which is a general no-no. The sensor has a heater element that gets PWM'd by the controller so you'll get a lot of current cycling on and off and sharing this power ground with other sensitive grounds will cause noise. Try grounding the gauge directly to the battery. Second thought it potentially bad sensor. It's not common but every once in a while you're get a sensor that goes bad and seems especially noisy. If wiring changes don't improve things, try a new sensor. |
2nd May, 2017 at 01:05:53am
At least you got an answer back, and one that appears to have been authored by someone who is not a muppet. That says a lot.
2nd May, 2017 at 07:04:08am
I agree with all the above, PWM generated noise from the LSU heater.
2nd May, 2017 at 05:11:29pm
had a play around with it after work and still cant get it to work, earth it straight to the battery and still had the same problem, rang nodiz and they said that ive fitted the sheiled cable correctly and the gauge normaly works fine, so i might just bite the bullet and buy a new sensor |
2nd May, 2017 at 05:51:21pm
Where are you based? Is there anyone local that could lend you a sensor to try? In the 13's at last!.. Just |
2nd May, 2017 at 08:37:07pm
i live in south wales, dont think any of you lot are around here :L
