| Home > Help Needed / General Tech Chat > Tacho Mounting & Centre Binnacle (stupid) Question | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
2nd May, 2017 at 09:47:44am
Hi Gents
Edited by t@z on 2nd May, 2017. |
2nd May, 2017 at 09:56:27am
Where have you mounted it? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd May, 2017 at 09:59:49am
On 2nd May, 2017 MikeRace said:
Where have you mounted it? i havent at the moment. just was holding it to see how it looked in places. I seemed to work well best in front off the steering wheel on the back edge of the dash rail but i remember it sitting to low and lacking mounting points. Was in line with the rack holder mounts. T |
2nd May, 2017 at 10:06:26am
I had mine mounted on the dash rail just to the right of the center clocks. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd May, 2017 at 10:06:58am
It was pretty much the same mount too, but the clock deed so it went. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd May, 2017 at 10:10:34am
It was pretty much the same mount too, but the clock deed so it went. Thanks Mike, will a picture be in your build thread? Also do you remember needing to space it up slightly so it cleared the dash rail or just to the bottom off it. Not sure if i am being really stupidly dumb but mine just didnt look right, like it was to low. T |
2nd May, 2017 at 10:15:54am
I dont have any pics, I didnt mount it in the bottom of the dash.
2nd May, 2017 at 11:02:00am
I'll have another go later using your description above. |
2nd May, 2017 at 12:48:10pm
Haha sorry if my description is confusing. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2nd May, 2017 at 01:05:13pm
found this...
2nd May, 2017 at 01:10:51pm
Yes that t@z, pretty much identical. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
3rd May, 2017 at 08:43:48am
this my tacho set up....
the pissed up clown stood back up, did a twirl and left bollock naked, |
3rd May, 2017 at 09:01:29am
On 3rd May, 2017 Oli said:
this my tacho set up.... https://www.facebook.com/MiniSportLtd/photo...?type=3&theater is that an addon like the old speedwell one? |
3rd May, 2017 at 09:41:48am
its the complete binnacle, so one piece, so it screws on over the top of the white single binnacle with the metal plate over the top as per mk1 if you're with me? Edited by Oli on 3rd May, 2017. On 15th Jul, 2009 fastcarl said:
