| Home > Help Needed / General Tech Chat > MPI oil temp sensor wiring | |||||||
167 Posts Member #: 11091 Advanced Member |
11th May, 2017 at 09:57:21pm
Had a good google on this to no luck
257 Posts Member #: 11017 Senior Member Shropshire |
11th May, 2017 at 10:32:21pm
Mpi circuit diagrams
108 Posts Member #: 9182 Advanced Member |
12th May, 2017 at 09:57:12pm
I had a look at the MPi wiring diagram and it is definitly wrong. The way it is drawn would show a full scale deflection on the needle all the time. I would think it works the same as the temperature gauge, the sensor sends a 0-5v signal to the ECU which than sends either a 0-12v or a modulated pulse to the gauge. When I get an MPi in next I'll check the cabling. |
12th May, 2017 at 10:31:59pm
The oil temp gauge on the MPi reads directly from the oil temp sender, the ECU plays no part in it. On 26th Oct, 2004 TurboDave16v said:
13th May, 2017 at 11:08:02am
It's been a while since i had a look at the oil temp gauge, what are the colours on the wires in the plug? |
13th May, 2017 at 05:16:31pm
I don't have any cabling or plug sensor side
13th May, 2017 at 05:24:09pm
Attached a pic - MPI equipment, non mpi car so that's just a universal plug
13th May, 2017 at 07:05:15pm
Whats missing on wiring diagram is the G terminal on the clock and the sensor. If Sprocket is correct and the ECU is not involved I would imagine the Black and White go to the gauge - and + as per the diagram and the G is connected to the sensor with the other sensor connection going to earth. If somebody with a MPi can confirm the cable colours at the sensor as one black and the other any colour with a black trace then I reckon thats it. |
