Home > Help Needed / General Tech Chat > What spark plugs have you guys had good luck with (or bad luck) on the k1100?
(Turbocharged of course) *hehe!*
Just curious - especially if you've had some that simply didn't seem to work well for you.
Edited by turbodave16v on 13th May, 2017.
Evoderby
Member #: 9987
Amsterdam
No experience with 16V turbo mini, but my 350HP integrale evo really liked NGK B8 EGV originally developed as a 2-stroke motocross spark plug. It shows great resiliance to fouling up, even when using very rich 'turbo-AFRs'. I know it's not a mini, but it's 16v, turboed and won the monte carlo multiple times so there have you *wink*
Will
Member #: 11091
OT but ooo i miss my integrale :(
can we have some pics bud?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I was going to ask the same thing, sounds interesting!
On 7th Nov, 2008 Nic said:
naeJ
m
Evoderby
Member #: 9987
Amsterdam
I'll look them up tomorrow guys, don't have any grale pics on the ipad.
What actual fitment does the head need ?
TBH anything NGK or Denso, is hard to go wrong by as long as heat range and fitment are correct.
Fouling is usually down to crap ignition, crap running or other similar problems.
Well I saw one of these B8EGV plugs on Amazon for a whopping $2 with free shipping. I can confirm it is not compatible for the Bmw k1100 / k1200 head as it's a 13/16 hex instead of the 18mm on the stock plugs. A 19mm hex plug will just about work, but might be a little tight if your plug socket is a tad oversized.
Sprox and Jimbo had given me some other suggestions; I'll take a look at those, but make sure whatever you choose has a 18mm or 19mm hex only!
Edited by turbodave16v on 20th May, 2017.
giannoutsos
Member #: 8952
Athens Greece
Hi Dave,
I have tried BR8EG plugs in my national aspired 1360 pretty good plug very resilient to fouling.
BR8EG won't fit
Standard plug is DCPR7E
gdouglas
Member #: 11577
You can't go wrong with NGK brand. Worth the cost.
