Home > Help Needed / General Tech Chat > Megajolt base map needed / Run in advice
Will
Member #: 11091
I'm aware people aren't too keen on sharing maps because of the cost involved making them in the first place
But I'm getting to the stage where I'm gunna need a safe base map to "knock" the cam in and get me to the Rolling road! *happy*
Spec is
1293cc
31/30 valves
Phase 2 cam
GT17 turbo
8.23 CR
Bit of searching brought this up;
On 19th Sep, 2011 John said:
Don't have the map file to hand but this is pretty much it. We have 2-3 degrees more advance in the 180kpa+, 3000rpm+ area though now.
Any advice greatly received re; boost to run in etc.
Also anyone know and good RR places familiar with MJ/Nodiz in the London/ south area?
Or anywhere worth travelling to?
VMax Scart/Stuart is on my doorstep pretty much for example
longy
Member #: 2727
Bicester
James has kindly uploaded the base maps from Megajolt
http://jamesfawcett.co.uk/megajolt-tuning-maps/
Edited by longy on 18th May, 2017.
1972 998 TURBO SLEEPER
jonny f
Member #: 9894
Dorking
Stuart set mine up.
No problems. Similar spec.
Where are you? Should join our club!
t@z
Member #: 452
Chester, UK
i just ran mine on the std loaded map to get me through basic stuff. when stuart rr'd it tbh it only really changed the numbers mid/top.
www.twitter.com/lilpinkiy
looks like a good start. maybe back off a couple of degrees to be safe on boost, always better to start a little retarded so you dont hurt anything.
yeah, Stu at V max will be ok, take your laptop so it all just plugs in, and hell run it and tell you what numbers to stick in where.
make sure you get some figures in there for cruise speed, a lot of RR places dont pay a lot of attention to this so your throwing away fuel economy.
I think most people used John and Andys map off the Old Metro Van lol
t@z
Member #: 452
Chester, UK
this is mine i think... says final :/
MJ
https://www.dropbox.com/s/ueasso3qzd9l2v8/l...final.mjlj?dl=0
Nodiz (imported)
https://www.dropbox.com/s/ghe0qo50nxdcnxd/l...odiz.nodiz?dl=0
edit: links will become useless in week or so as i will clean up my public folder
Edited by t@z on 18th May, 2017.
Will
Member #: 11091
Thanks! What's the spec of your engine bud?
MJ
Nodiz (imported)
I'm from Kingston SE London - down the road from Brooklands!
Ok will take it to Stu when I'm ready
What do you do for better economy at motorway speeds?
I'm running a 2.7 diff and 13 x7" wheels so probably be around 3/3.5k at 70/75
t@z
Member #: 452
Chester, UK
bit vague sorry as i converted a 1293 i purchased so...
- 1293
- T2
- 10psi
- a pretty mild unknown cam.
Ran like a dream and engine looked perfect when i took it a part (tops off pistons etc)
FYI my engine is similar spec to yours above and i am using my old base map to get me going and the cam bed in
MJ
Nodiz (imported)
