Page: |
Home > Help Needed / General Tech Chat > Blue Smoke/Low Compression on New Engine | |||||||
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
16th Jun, 2017 at 08:27:18am
what did you lube the rings with on assembly(in-case its relevant)
168 Posts Member #: 10666 Advanced Member California, USA |
19th Jun, 2017 at 06:37:15pm
No chance for further tear down this weekend but a couple comments:
336 Posts Member #: 9941 Senior Member Derby |
20th Jun, 2017 at 07:53:46am
100% bore wash then, I had the same problems you described and it was this! |
20th Jun, 2017 at 08:20:57pm
well that's a good lead, potentially. What did you do to fix it?
21st Jun, 2017 at 12:58:37pm
it isnt that simple, one of the functions of the crosshatching on the bore is to retain a little oil so the rings have some lube, they are metal on metal but they still need some lube.. if crosshatching gets wiped of the bores before the rings get the chance to bed in, its game over. I should point out im no expert, I have likely built more engines than most but certainly dont know everything so this is just my understanding. turbo 16v k-series 11.9@118.9 :)
22nd Jun, 2017 at 05:23:24am
Okay, made it out to the car for a little bit of work.
Edited by seahuston on 22nd Jun, 2017. |
22nd Jun, 2017 at 05:50:41am
If the clearance really is 0.011" then way too much.
6743 Posts Member #: 828 Post Whore uranus |
22nd Jun, 2017 at 07:35:07am
like i said , just bung a piston in the bore and see what feelers you can get down the skirt to bore gap . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
7263 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
22nd Jun, 2017 at 12:59:39pm
If I'm reading that correctly, your pistons measure larger than the bore? In the 13's at last!.. Just |
22nd Jun, 2017 at 02:54:06pm
you need to measure the psiton near the bottom of the skirt 90 degress to the pin, as the pison is tapered so it is the right shape when up to temperature. ( they expand A LOT)
22nd Jun, 2017 at 11:02:05pm
Well looks like I TOTALLY buggered up that measurement. So let's just ignore that and pretend it didn't happen lol :)
23rd Jun, 2017 at 06:13:38am
Okay. So I got out there and dude this:
23rd Jun, 2017 at 07:31:47am
So say .0045"
23rd Jun, 2017 at 08:19:20am
yup i agree with rod ,
23rd Jun, 2017 at 05:25:22pm
Well fook, machine shop was friendly but the owner is out until next week.
Page: |
