| Home > Help Needed / General Tech Chat > Off topic/non-mini help- the mrs' polo (again) | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
13th Jun, 2017 at 05:39:02pm
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
13th Jun, 2017 at 05:44:32pm
Little breather clogged with oil putting more pressure out the other one? |
13th Jun, 2017 at 11:02:25pm
The breather with the universal filter is fine, the little one coming off the top of the cam/rocker cover is where all the oils coming from..
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
14th Jun, 2017 at 07:36:11am
Have you done a compression test?
Edited by shane on 14th Jun, 2017. |
14th Jun, 2017 at 11:18:13am
You blown through it?
14th Jun, 2017 at 04:25:37pm
Shane- long time no speak (on here)
14th Jun, 2017 at 04:49:35pm
On 14th Jun, 2017 D4VE said: Shane- long time no speak (on here) I will do compression tst but problem is its always in use to ever have any time to actually sort nowt, i am thinking rings are probably fucked as it did eat a plug a while back.. its defo not too much oil as its always needing oil because it throws it out Jonny- this breather that the oils coming through is a tiny metal tube off the cam/rocker then to a pipe, the pipe isnt blocked and the metal tube is clear to see through
14th Jun, 2017 at 04:49:38pm
14th Jun, 2017 at 07:55:27pm
Awesome look forward to seeing it done!
15th Jun, 2017 at 11:07:28am
Not what i'm saying.
