Home > Help Needed / General Tech Chat > Anyone got any links to a trusted exhaust calculator
JetBLICK
Member #: 1261
Droitwich
For optimizing primary lengths and pipe diameters, system lengths etc etc? I can only seem to find ones for V8's..
Thanks, Dan
whats it for, it always ends up a bit trial and error anyway imo
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i think i read that someone found that the normal port per cylinder ones still apply?
im probably wrong tho..
JetBLICK
Member #: 1261
Droitwich
An N/A k1100 conversion. Yea I can imagine it takes some tuning, I've got the specs for the cams so I'm hoping i can work out somewhere to start..
Sir Yun
Member #: 1592
Smart Guy!
Pipemax is good for non 5port configs , gives a lot of other data as well. Pretty cheap as well. Maxracesoftware. If you are not in a hurry I could see what EngMod does but that takes quite a bit of setup time and half an hour of waiting on the computer to finish. i have found that it is really hard to improve on Pipemax
Edited by Sir Yun on 18th Jun, 2017.
JetBLICK
Member #: 1261
Droitwich
Thanks, I'll check it out..
I found this one http://www.mezporting.com/exhaust_length.html
Says the calc's come from a graham bell book?
