| Home > Help Needed / General Tech Chat > Max boost on a stock A+ | |||||||
13 Posts Member #: 11468 Member Milton Keynes |
20th Jun, 2017 at 08:30:04pm
How much boost would be the limit for a stock bottom end on a A+ 1275?
20th Jun, 2017 at 10:54:29pm
Standard NA A+ pistons, or turbo type ?
21st Jun, 2017 at 07:53:49am
They'll be standard pistons. I've punched the engine code into guessworks and its an A+ that was 9.4:1 compression from factory.
21st Jun, 2017 at 08:13:57am
With 9.4:1 compression it won't take much boost at all. You need to budget in lowering compression with either different pistons or a worked head. I doubt it will be any cheaper than the NA route. |
21st Jun, 2017 at 08:45:37pm
I disagree. The MT turbo ran up to 7psi on 9.4:1 and made 94hp if you believe the spec
1391 Posts Member #: 1686 Post Whore Oxford |
21st Jun, 2017 at 11:24:47pm
Methanol injection is going to be your friend. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
22nd Jun, 2017 at 07:58:41am
I'm the same vein, once you spend the money on everything to make it run at high compression you may as well have gone the NA route. I don't think there's a cheap way. |
22nd Jun, 2017 at 08:21:13am
Max 9psi boost, decent intercooler and a rolling road set up to ensure it's getting enough fuel should see north of 100hp. After that yes I would start opening things up. On 7th Oct, 2010 5haneJ said:
22nd Jun, 2017 at 08:56:58am
So theoretically 9 psi on a completely standard engine is possible?
22nd Jun, 2017 at 09:39:16am
9 psi on standard metro turbo pistons would be no problem, but from what you have said it appears you are talking about a standard 60bhp NA 1275. The pistons might not be up to it. |
22nd Jun, 2017 at 09:40:49am
We did run more with a rich needle and decent intercooler, but as per the other comments I wouldn't advise it! To be honest if it's a bog standard non turbo 1275 they are all getting old I would just rebuild it, or boost it and accept it may not last. The turbo pistons are a stronger design so compression is only part of it. Edited by minimole23 on 22nd Jun, 2017. On 7th Oct, 2010 5haneJ said:
22nd Jun, 2017 at 01:18:52pm
There is no cheap way to boost an engine, you can literally throw a turbo on it and the carb etc, but it will end up goosing your engine and you will have lost everything.
Edited by Carlzilla on 22nd Jun, 2017. On 26th Jan, 2012 Tom Fenton said:
