| Home > Help Needed / General Tech Chat > Stock 1000cc box | |||||||
32 Posts Member #: 10074 Member new Zealand |
25th Jun, 2017 at 09:17:40am
Will a 1974 gearbox 1000cc with a cross pin diff handle turbo power...
25th Jun, 2017 at 09:32:25am
yeah, all the gear kits are prety much the same, some people say the older PreA+ ones are a bit stronger, but doubt theres a lot in it either way.
25th Jun, 2017 at 09:34:12am
you can swap that gear kit into the later 3 bolt case, but you'll need to file the case for the 3rd motion shaft which is a smaller dia and longer on the early gear kits. On 28th Aug, 2011 Kean said:
25th Jun, 2017 at 09:52:42am
Thanks for the info joe c... love how helpful you guys are to us newbies hahah. So if I used the 1000cc box and fitted 1275 drop gears from a remote type box I have will this work.? .
Edited by uk boy on 25th Jun, 2017. |
25th Jun, 2017 at 10:11:50am
Yep that will do the trick,
25th Jun, 2017 at 10:18:21am
I see..
25th Jun, 2017 at 10:22:23am
it would be an idea to replace the bearings, but as a 1000 its probably not had a hard life. pull the dif pin out and have a look, thats gennerally a good indicator of how shot well looked after its been. On 28th Aug, 2011 Kean said:
25th Jun, 2017 at 10:28:49am
Ok sweet will do... I'm hoping it will be ok.. any other advice?😀 |
25th Jun, 2017 at 11:13:57am
not really,
25th Jun, 2017 at 12:36:37pm
oh, have a look that the syncro teeth look in reasonable shape. On 28th Aug, 2011 Kean said:
