Home > Help Needed / General Tech Chat > Regulator for the plastic K (1200?) fuel rail
I just realised the standard Bosch regulators used on many Audis Mercedes, etc. don't fit The plastic fuel rail as the smaller O ring diameter is approx 1.5mm smaller on the K rail vs the regulators we're all more familiar with.
So, does anyone know what regulators do work, that are vacuum / boost referenced?
One around about 3.5 3.8 bar would be good *smiley*
Edited by turbodave16v on 27th Jun, 2017.
hmmm im sure lads of boosted bimmers use these, i think they are the std weber pattern.
Peirburg. Still fitted to many BMWs and Audi's..............
Give that man a banana !!!
I should have looked at it more closely. Oh well, I'm now using the steel fuel rail with 6AN fittings silver soldered on, which is what I wanted to do in the first place; I just figured the plastic rail would have saved me a little time!
Best of both worlds Dave *happy*
*Clapping*
so is that regulator housing stainless?
Yes
think Im going to end up doing somthing like this, as I want to put pressure and temp sensors in the rail.
Does the current reg have no reference port on it at all ?
For temp/pressure, you can buy combined temp/pressure sensors.
Yes Steve, the k1200 reg has an open hole port, not a hosetail. So it will adjust to atmospheric only but no chance of feeding boost to it. I like Sprox's idea of splicing a reg end plundered off a different rail onto the end of the steel one; he even added a leakoff port!
I'd purchased the jenvey Bosch regulator housing previously, and it is an absolute gem, so this is what I have ended up using.
http://www.jenvey.co.uk/products2/accessor...ing-9-4mm-rh01m
Edited by turbodave16v on 30th Jun, 2017.
http://m.ebay.co.uk/itm/AUDI-A2-2000-2005-...%257Ciid%253A12
Dave I have a similar reg. actually the webcon one, I was thinking of just putting an AN fitting each end of the rail, and a screw in female one on the reg.
Intrstimng steve, id only seen the seperates I'll take a look
can you adapt, epoxy, whatever a fitting into it ?
Radium make some regs in a similar sort of style
http://www.radiumauto.com/Fuel-Pressure-Regulator-P229.aspx
I was about to buy the radium, and happened across the Jenvey for 2/3 the price, which made the descision easy!
