Home > Help Needed / General Tech Chat > Bottom rad hose in the way of fitting turbo air feed pipe
belcher9744
Member #: 11429
Hi there, have a issue with Bottom rad hose in the way of fitting turbo air feed pipe, has anyone got any suggestions? Maybe different bottom hose that they've fitted? Any help appreciated
What turbo is it?
It's always tight, I've used flexi hoses before, or a 90deg silicon hose.
tadge44
Member #: 2500
Buckinghamshire
If it is a GT1752 I used a modified Saab inlet pipe and flexible, otherwise, as Wil says just use flexible.
belcher9744
Member #: 11429
Thanks for the feedback, this site is helpful as always
