Home > Help Needed / General Tech Chat > Pistons needed 9.4:1 or close....
fastclown
Member #: 5067
What turbo pistons are available (.040) to keep the standard compression. Or a close compression ratio as I can make up the difference with the head. What and where would I find them? Options?
Thanks!
Mike
The 10cc cast Omegas sit around 0.040" down on a standard block. This will give you damn close to stock compression.
Phil.
