Home > Help Needed / General Tech Chat > 1293 emissions pass help!!
Georgeb
Member #: 10810
Kent,medway
Good evening
Before I build the last bits on my engine I need some advice
My car is registered September 1992 which means it's a carb with a cat unfortunately, one month earlier wouldn't have needed one. So that means emissions are tighter. So can I pass an mot on emissions with a turbo engine or am I going to have to scrap the turbo ?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=462092
It's a carb model with a cat..... Bin the cat off and make sure the tester is using the appropriate test for the VIN. The VIN will identify the car would have had a Carb engine, and there is no in service data for it, as such, the Basic Emissions Test should be carried out, which is pretty much just the same as Pre August 1992
Georgeb
Member #: 10810
Kent,medway
Thank you. Just don't want to get to the MOT and it fails would be a pain
