Home > Help Needed / General Tech Chat > Help needed!!! Gt1752 manifold??
Buckersturbo
Member #: 11648
Hi, can I fit a gt1752 on a standard metro turbo manifold, if so would it fit without modifying the bulkhead?
hazpalmer
Member #: 9038
Carlisle, Cumbria
Correct me if im wrong but i think it wont work! The matty or mirage style manifold the turbo sits very close to the block and it is a tight squeeze against the bulkhead too
Yes you can adapt the Metro manifold to accept a GT17, but you will need bulkhead mods.
Phil.
longy
Member #: 2727
Bicester
Just as an example ive got a Fusion manifold with a GT1544, the compressor housing touches the block and theres 5mm to the bulkhead.
1972 998 TURBO SLEEPER
longy
Member #: 2727
Bicester
