Home > Help Needed / General Tech Chat > Chargecooler radiator
steve w
Member #: 1917
AKA chargedzetec
Does anyone know of a directory for radiator sizes?
I’m looking for one approx 600x250x25, ideally with 19mm outlets, to use in front of my radiator for the chargecooler.
Core size or overall? That's basically fiat cinq rad size.
I was thinking that sounds pretty huge for a charge cooler rad, i would expect somthing more in like with a scooter rad.
shane
Member #: 1246
Lowestoft, Suffolk.
Is there a rule of thumb for water volume per BHP for these?
Shane
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
will 660x175x50 fit?
dont know a lot about this but from what ive figured out and looked around
http://www.frozenboost.com/water-to-air-he...tor-p-1063.html
volume is just time to change temp move volume slower temp rise but also longer cool off time
the "best" setup is the largest but more importantly slimmest rad that will fit away from hot stuff with good cool air flow
this will land the water temp as close as possible to what the ambient air is
a thick rad cant get near as good as thin ones as the thin ones a good example is the A/C heat exchanger
the thing to watch out for and that catches people out is the actual charge cooler normally a unit to small is fitted ie a barrel.. the air needs surface area and time to dump its heat off into the coolant
steve w
Member #: 1917
AKA chargedzetec
Yeah, too thick.
My contact at PWR has told me to go for no bigger than a 25mm core, hence why I’m struggling a bit!
Steve220
Member #: 11017
Shropshire
Could you not use a large heater matrix from a large car?
Ive planned on running Twin Motorbike Rads off a Crosser.
steve w
Member #: 1917
AKA chargedzetec
The research I’ve done so far says that motorbike rads are rarely efficient enough.
Also that sealing the rad is quite important.
Think I’m just going to get a custom one done....
I was gonna try these, one either side in each rear wing.
https://www.ebay.co.uk/itm/high-perf-alumin...8AAAOSwd4tT-FHq
Together they look about the Size of a Mini Rad. By the looks they are 40mm Core, but you get the idea.
Edited by MikeRace on 9th Nov, 2017.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
if mine ever gets back together ill post up how bad or good ive changed it since last time
from the brief time it was together i can say that it worked well although heat soak was an isue if it was parked or stood at the lights
when you took off and the temps would stay high until the rad had fresh air and had time to dump the heat out this was a big problem despite the fans running
but that said once you got going it sorted its self out it was grate just a nice steady temp rise that always lagged behind the boost you could roll race it and have the temps hold a few degrees above air and slowly rise
but by then you have lifted off and are coasting down so the higher temp is fine at that point
buy the time you coasted down you could hit it again with fresh cold air
with good ducting i think most of the standing temp rise could be done away with just a case of getting the hot air to go away from the ic rad
