| Home > Help Needed / General Tech Chat > GT17 watercooling with MPI setup | |||||||
167 Posts Member #: 11091 Advanced Member |
26th Nov, 2017 at 03:39:33pm
Attached the cooling diagram of my current setup (42mm ally mpi rad)
Edited by Will on 26th Nov, 2017. |
257 Posts Member #: 11017 Senior Member Shropshire |
27th Nov, 2017 at 02:51:14pm
I was in the same boat as you regarding this situation. I worked backwards from what I had on my Rover 220 turbo and Evos.
27th Nov, 2017 at 04:27:21pm
To get flow you need to take the water from the high pressure part of the system. This is between the pump and the thermostat, problem is that it is only easily accessible where it is also the hottest. Return is best after the thermostat and before the rad.
27th Nov, 2017 at 07:57:48pm
is it true that the center houseing should be rotated slightly to put the water out a bit higher to promote after shutoff flow thermochifin or what ever |
10th Dec, 2017 at 06:18:55pm
Just checking before I order the bits but this is my thinking
11th Dec, 2017 at 12:40:59am
If it were me and you've still got all the original MPi plumbing, I would splice the turbo cooling into the T section on the bottom hose indicated as number 4. This is a bypass (replaces the bypass hose and stubs on the head and water pumps on a lot of the earlier engines). There is a 6mm plastic restrictor in that section near the top T, which can be removed. Incidentally, the arrow in the picture shows the wrong flow direction. On 26th Oct, 2004 TurboDave16v said:
