Home > Help Needed / General Tech Chat > Starter motor help
D4VE
Member #: 10749
lowestoft suffolk
So my friend has a 90's mini but has just brought a engine from a 83 mini which has the older style starter
Whats involved in using the newer wiring with old starter?
Thanks in advance...
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
Would imagine the 83 is pre verto.
Time it takes to swap the clutch over while they’re both out you’d be better off doing that and keep the 90s pre engaged stuff and the nice verto clutch.
slater
Member #: 1291
Suffolk / Birmingham
If you mean inertia to pre-engaged starter then I believe you should change the flywheel ring gear too no? Makes it a bit more effot than its worth. To wire it is easy. The solenoid is just separate on older types.
jonny f
Member #: 9894
Dorking
Pretty sure he just means plonking the engine in as is and just changing the wiring over to inertia.
My opinion it would be quicker and better to just swap the lot over from the engine that’s coming out.
D4VE
Member #: 10749
lowestoft suffolk
Sorry should of mentioned there is no engine in car.. so just 90s wiring... old motor
viz139
Member #: 9182
Just mount a solenoid close to the starter motor . Join the existing wireing loom to the solenoid and a large cable from the solenoid to the inertia starter.
