| Home > Help Needed / General Tech Chat > Thread tap extension required. Do they exist? | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
28th Jan, 2018 at 02:30:20pm
Guys, I'm after a thread tap extension to tap some M8x1 threads for the undrcrown cooling jets.
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
28th Jan, 2018 at 03:27:08pm
If you have an appropriate sized socket, wedge it in there and give it a whirl. or another, if you're feeling brave and skilled in the tapping ways, put the tap in a drill chuck and you'll be done in no time.
David. |
28th Jan, 2018 at 04:28:14pm
how about this?
28th Jan, 2018 at 05:02:09pm
Perfect Joe, that's just the job, thanks
On 28th Jan, 2018 Joe C said:
how about this? https://www.ebay.co.uk/i/292171176217?chn=p...74960578&crdt=0 |
29th Jan, 2018 at 04:49:38pm
If it is just a one off job I weld an extension on to the tap |
29th Jan, 2018 at 10:51:36pm
youll find a 12 sided socket will fit if you have a good socket set that doesnt skip sizes. I use this method when my 3/8ths drive tap chuck is too bulky to fit in somewhere. turbo 16v k-series 11.9@118.9 :)
30th Jan, 2018 at 07:59:15am
I've done as Denis in the past (as 12 divides by 4) but 4 sided sockets especially for taps do exist,
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th Jan, 2018 at 09:23:41pm
I used a piece or round bar with a hole in one end to insert the tap into, a grub screw positioned to locate on the square “Drive” of the tap. Worked a treat, I did try to post a picture but failed miserably.
31st Jan, 2018 at 06:45:51pm
Hopefully there is now an image and it helps?
Edited by shane on 11th Feb, 2018. |
