| Home > Help Needed / General Tech Chat > Inertia to pre-engaged starter wiring trouble | |||||||
167 Posts Member #: 11091 Advanced Member |
28th Jan, 2018 at 03:20:02pm
Keeping it simple I’ve found out I’ve got an early loom (the one with the junction box and inertia starter)
28th Jan, 2018 at 03:25:14pm
Also 8mm lines from fuel regulator to 6mm carb connections
28th Jan, 2018 at 07:28:46pm
You definitely need to use some sort of relay to operate the pre-engaged starter solenoid or your ignition switch barrel will fail (maybe not today, maybe not tomorrow, but it definitely will....)
7 Posts Member #: 11683 Junior Member |
28th Jan, 2018 at 07:52:46pm
Like this?
Edited by Austin on 28th Jan, 2018. |
28th Jan, 2018 at 08:12:26pm
Not the usual solution but, in conjunction with the wing mounted solenoid, it would certainly work. (without the wing mounted one as well, the starter would just run all the time).
Edited by Rod S on 28th Jan, 2018. Schrödinger's cat - so which one am I ??? |
28th Jan, 2018 at 08:56:07pm
Ok I’m running mappable ignition so coil isn’t an issue really
