| Home > Help Needed / General Tech Chat > Knock sensor position. | |||||||
4th Feb, 2018 at 08:56:28pm
For those of you that have experimented with these, which, if any position did you find worked best or at all ?
4th Feb, 2018 at 09:08:17pm
short bolt of the engine steady on the head for me Phil Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Feb, 2018 at 10:29:12pm
Mines in the same position as Roberts. The ecu is compatible but I’ve Never got around use it tho 😳 I run a supercharger and I don't care the TB is on the wrong side.
4th Feb, 2018 at 11:39:18pm
Thanks chaps.
5th Feb, 2018 at 10:17:30am
Engine running but not yet tested.
6th Feb, 2018 at 07:40:26pm
I've seen the knock data from mine and the signal is very noisy when you get the engine going. Not had a chance to look at it in detail yet, but will have to do so to be able to set up Knock sensing propperly. My sensor is mounted on the very top screw for the coil mounting bracket on the MPi block. On 26th Oct, 2004 TurboDave16v said:
224 Posts Member #: 9987 Senior Member Amsterdam |
7th Feb, 2018 at 08:16:40am
I’ve seen Swiftune use a 70mm long brass pipe, squashed flat on one side...then drilled and screwed to the upper alternator bracket thread in the block. Over the other -still round- side of the pipe a length of fuel hose is fitted...put the other end in your ear and hey presto, you can now listen to knock!
7th Feb, 2018 at 04:58:01pm
On any vehicle I have ever seen with knock sensors they are aprx half way up the cylinder bore, on the block. that makes the upper alt braket bolt location almost perfect. my only concern there would be potential noise from the alternator itself. I have never experimented on an a-series with knock placement, but seems a good place to start for me. turbo 16v k-series 11.9@118.9 :)
7th Feb, 2018 at 06:39:42pm
Link to a picture on facebook of the swiftune analog setup:
7th Feb, 2018 at 07:46:19pm
When I have had my car on the rolling road. We have always fitted it to the alternator bracket. |
8th Feb, 2018 at 05:46:43pm
Just came to mind, my 16V Lancia Integrale Evo had its OE knock sensor fitted on the cylinder head close to the head gasket so your solution might just work perfectly.
In theory same distance from chamber to sensor for all 4 cylinders and away from valve gear should give decent results. Edited by Evoderby on 8th Feb, 2018. |
8th Feb, 2018 at 06:08:18pm
I'm a bit puzzled by the comments that the best location is on the block. I know very little about knock but it is well documented that it usually ocurrs between TDC and 10 Degrees ATDC which means that the block is hardly exposed to the pressure pulse whereas the head gets a hammering.
8th Feb, 2018 at 06:12:26pm
Most of the oe sensors I have seen are on the block. My thinking was that the noise gets transmitted down the rod into the crank and into the block by the mains, hence the sensor is listening for it there. But happy to be told otherwise.
9th Feb, 2018 at 01:16:54am
And just to throw my tuppence in, (seing as we are lol) knock frequency is a function of the bore. That is to say knock is the "ringing" of the bore. so knock will always be picke dup most accurately on the block, on an area coupled mechinically with the bore close to where the event occurs.
Edited by evolotion on 9th Feb, 2018. turbo 16v k-series 11.9@118.9 :)
9th Feb, 2018 at 09:23:51am
a soupcon of input ,
9th Feb, 2018 at 10:47:25am
Interesting paper on the subject here:
