| Home > Help Needed / General Tech Chat > Ignition switch no power | |||||||
13th Feb, 2018 at 01:40:59pm
Hi all I have a strange issue, when I turn the ignition switch to the first position the power goes out on the car.
Edited by gr4h4m on 13th Feb, 2018. I run a supercharger and I don't care the TB is on the wrong side.
108 Posts Member #: 9182 Advanced Member |
14th Feb, 2018 at 02:24:17pm
On a MK2 the only things ON when the ignition is OFF is the headlights,horn and interior lights. Are you saying you loose all these when you turn the ignition switch to the first position? If so it would have to be a bad connection the Battery, earth strap or solinoid. If it still has a dynamo and regulator it could possably the regulator Edited by viz139 on 14th Feb, 2018. |
17th Feb, 2018 at 03:21:33pm
Well, it was the battery, it just died I run a supercharger and I don't care the TB is on the wrong side.
