| Home > Non-Mini Discussion > Helicoils and Brake Carriers | |||||||
21st Mar, 2018 at 08:12:14pm
Doing the brakes on my wife’s car, single pot sliding caliper jobs and one of the threads on the carrier which the “slider bolt” (not sure of the correct term) screws into is badly chewed up. Given the way they are loaded can I drill it out and helicoil it or do I need to replace the carrier? If it helps my wife does not have life insurance. Isambard Kingdom Brunel said:
21st Mar, 2018 at 08:31:14pm
Struggling to visualise the arrangement. Does the slider bolt have a thread next to the head then a longer plain sliding shank? If so I’d not worry about helicoiling it as long as there’s sufficient meat around the thread. But how has the thread got mangled in the first place?
3596 Posts Member #: 655 Post Whore Northern Ireland |
22nd Mar, 2018 at 12:17:33am
Not a thing wrong with helicoils when used correctly.
22nd Mar, 2018 at 01:21:38am
No probs with a helical,
22nd Mar, 2018 at 08:14:56am
Thanks everyone, figured I’d check first. I’m pretty sure that the damage to the threads was a result of hamfistedness in the past. Isambard Kingdom Brunel said:
22nd Mar, 2018 at 04:09:40pm
The slider bolt threads need to obviously be perfectly normal to the mounting, so using a pistol drill and hand held tap wrench is likely to generate issues.
