| Home > Help Needed / General Tech Chat > Pot joint problems | |||||||
30th Mar, 2018 at 04:39:02pm
So I'm finally getting a chance to sort out the drive shaft oil seal. I figured a while ago that the bush in the end plate was worn causing the oil leak. I ordered a new endplate, chucked that on and the pot joint didn't slide in too easy. It needed a bit of encouragement but I think the pot joint I'm using was one of those non-gen ones that are a bit tight. Now that it's on, it's seized solid and won't turn. There's no way that a hard spicer end plate would stil fit a pot joint but be really tight? I'm pretty sure I ordered a pot joint one. Of course it won't come back out now so the car is kinda stuck! I can't get the end plate off either as the pot joint is in the way... On 7th Nov, 2008 Nic said:
119 Posts Member #: 2576 Advanced Member South Staffordshire |
30th Mar, 2018 at 05:11:52pm
There was a batch of poor quality pot joints around a few years ago, with the slot for the retaining clip in wrong place. I have just ruined an end plate removing on on my car.
HOSS |
30th Mar, 2018 at 06:38:07pm
The pot joint always has been a bit tight getting it on and off, but it just won't turn in the endplate this time. I'm thinking there's a clearance issue with the bush as you say. It's really stuffed up my plans! I'm going to try and prize it off, worst case I'll put the old leaky one on. On 7th Nov, 2008 Nic said:
31st Mar, 2018 at 02:39:37pm
Yep! The bush is way too tight, so that's for the bin. The old one isn't actually that bad, so that's back on and the minis back in the garage. I'll huff for a few weeks than try work on it again... On 7th Nov, 2008 Nic said:
1st Apr, 2018 at 02:18:02pm
Silly question, but can you leak oil past the diff splines into the pot joint itself and leak out past the rubber boot? There is liquidy grease on the subframe around the pot joint, so I'm thinking this is what's happening. Edited by Jay#2 on 1st Apr, 2018. On 7th Nov, 2008 Nic said:
2nd Apr, 2018 at 12:37:05pm
The bush just needs machining / reaming to size. Few good YouTube videos on this.
HOSS |
2nd Apr, 2018 at 04:56:49pm
On 1st Apr, 2018 Jay#2 said:
Silly question, but can you leak oil past the diff splines into the pot joint itself and leak out past the rubber boot? There is liquidy grease on the subframe around the pot joint, so I'm thinking this is what's happening. Yes this can happen. The plug at the end of the splines is like a core plug and can move and create a leak. The good news is, if that has happened the pot joint rarely seized on the splines! |
2nd Apr, 2018 at 06:53:34pm
You're right it does cause a mess! There's a ton of oily guff around the subframe, I think the plug has moved a bit so I now know what needs done to fix it... in another few weeks when I muster up the motivation to take it all apart again... On 7th Nov, 2008 Nic said:
