Home > Help Needed / General Tech Chat > Fiat cinq rad Mounting & Pipes.
NickG
Member #: 7912
Australia oi oi oi!
Hi Gentlemen!
Can anyone help me out with photos on how you did your radiator mounting & plumbing.
I'm a little stuck, Once I can sort this out I can start it! :)
it's kinda just sitting in place right now until i can sort it out.
I have the bottom hose sorted fine, Im not sure what to do with the top house & overflow tank etc etc.
Not done any custom radiator stuff before.. surely it can be that hard.
Edited by NickG on 1st Apr, 2018.
NickG
Member #: 7912
Australia oi oi oi!
will I need one of these at all?
http://www.dsnclassics.co.uk/retrosport-sh...cer-retrosport/
jonny f
Member #: 9894
Dorking
Pretty simple!
Same as your old rad. Top hose in top bottom hose in bottom.
Then you need somewhere to fill it. Usually put a pressurised header tank in the heater line and T it back into top hose or into a thermostat spacer that you have linked. I’d run an expansion tank off the header tanks cap outlet to.
wilsonc001
Member #: 11333
With a removable front end, I'm not sure how much this will help, but this is what ours looks like (dirtier now!).
Edit:
Just realised how old that image is, coil-overs and 4-pot/vented breaks have since been changed out!
Edited by wilsonc001 on 1st Apr, 2018.
NickG
Member #: 7912
Australia oi oi oi!
Ok , Thanks. I roughly get how you pipe it up.. i'll give it a go & report back before I go to the next step. starting it up ha.
Do I really Need a sandwich plate? Or can i just T it back into the pipes?
I have a head tank as well.
jonny f
Member #: 9894
Dorking
You can T it in no problem. It’s what I have done on my front mount.
wilsonc001
Member #: 11333
No, the only reason I left mine in was because I wasn't sure what I was going to do with the heater. I drilled the left-hand outlet and run it through the manifold to the heater. You can't see it in that picture (because I hadn't fitted it) but the return from the heater is just T-ed back into the return to the pump.
Edited by wilsonc001 on 2nd Apr, 2018.
NickG
Member #: 7912
Australia oi oi oi!
Could you get a few photos if possible jonny f.
I got some hooked up.. ill pop up what i have tonight.
jonny f
Member #: 9894
Dorking
I have no heater
can see the T here line just through turbo first instead of a heater
different header can see outlet of header goes to expansion tank to help self bleed.
