| Home > Help Needed / General Tech Chat > rich idle? | |||||||
13 Posts Member #: 11444 Member |
12th Apr, 2018 at 01:30:24am
Maybe yins all can give some pointers.
12th Apr, 2018 at 05:52:50am
adjust the idle mix so that when you lift the pin a couple of mm ,the revs slightly rise then it drops back to normal idle speed , whats the mixture then ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Apr, 2018 at 09:13:39am
what WB is it?
12th Apr, 2018 at 12:22:31pm
When jet is adjusted so that when I lift the pin, the rpm rise slightly and fall to normal, my far is about 11-1
12th Apr, 2018 at 12:24:23pm
earth offset joe ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Apr, 2018 at 12:53:07pm
yep, thats what I was thinking, also Ive seen the gauge output incorrectly set if its changable, and likewise for the ecu input. and lets not forget the LC1 self calibration thingie.
12th Apr, 2018 at 12:53:39pm
Every engine build is different but A-series do seem to prefer to idle rich.
12th Apr, 2018 at 01:11:53pm
also ive found idle better up around 15 degrees advance, but you may not have the luxury of moving it.
12th Apr, 2018 at 07:51:25pm
What's your compression ratio ? If it's low it will require more advance at idle, as Joe suggested. Mine was set to 16deg iirc. If you're running an ECU this is a simple enough job to do, if you're on a dizzy then it's more of an issue unless you adjust it, then limit the total advance.
13th Apr, 2018 at 12:53:13am
Timing is set at 15 degrees.
13th Apr, 2018 at 07:51:26am
mmm, thats not altogether supprising, it should give the same mixture right up until the flowt bow emptys and it sucks air, but i would expect a bit of stumbling etc before it died.
