| Home > Help Needed / General Tech Chat > Recommended Boost Setting | |||||||
5 Posts Member #: 11740 Junior Member Midlands |
16th Apr, 2018 at 06:42:07pm
Hello Chaps,
16th Apr, 2018 at 07:24:47pm
what pistons, and compression ratio? and I assume youve got an intercooler on there? any head porting?
17th Apr, 2018 at 03:29:52pm
Hello Joe, pistons are standard plus 0.20 making 1293cc, yes intercooler is from an RS turbo I believe. I'm not sure of compression but cylinders have all been checked for pressure loss and all seems good. The carb is being fully serviced so hopefully the fuelling will be set right on the rolling road. I get a bit of over-run at the moment when the engine is shut down so I guess she is a bit rich? Thanks for your advice. |
17th Apr, 2018 at 07:21:47pm
I ran 10psi on Metro turbo pistons on a regular basis, with intercooler and up to 15psi for short bursts.
