Home > Help Needed / General Tech Chat > Smoking nightmare
flyingturd
Member #: 4008
near cardiff np12
Longish story!!!!
I’ve had this car 9 years and has had very little use.
1310 engine, was rebuilt 11 years ago and has done around 2000 miles.
When I bought it it never really smoked but never ran nice.
So I restored the mini and refitted the engine where it never ran right so I removed the engine checked the cr etc and put back together where I smoked!!!
So 2 weeks ago I removed the head to find a valve stem rubber split.... head back on with all new rubber and now it’s smokes even worse!!!
Head no back off with oil everywhere all valves are wet and all 4 pistons have puddles on them
I’m slowly giving up
Crack test the head?
slater
Member #: 1291
Suffolk / Birmingham
I saw your post on Facebook? Pretty sure it's coming from the turbo myself. For all 4 cylinders to be literally puddling with oil you have got to have a big leak into the inlet somewhere. Either that you have done somthing majorly wrong with the guides. That fact thay its every cylinder suggests turbo to me tho.
jonny f
Member #: 9894
Dorking
Turbo is pretty easy to diagnose. Have you got an intercooler? is it full of oil?
flyingturd
Member #: 4008
near cardiff np12
Intercooler and pipes are brand new and no oil.
Any recommendations to send the head too? Thanks
my moneys on a carb problem so its been masivly rich and washed the bores
flyingturd
Member #: 4008
near cardiff np12
Bores look good with a cross hatch look?
How can I tell if they are washed thanks
DILLIGAF
Member #: 9128
If it's the pic I was shown today on fookface, on a phone screen it looked like the boring had broken into the oil gallery on number 4 cylinder (one at the top of the pic).
flyingturd
Member #: 4008
near cardiff np12
Untitled by rhos jenkins, on Flickr
Edited by flyingturd on 13th May, 2018.
Have you tried with just one head gasket to eliminate that?
flyingturd
Member #: 4008
near cardiff np12
no was thinking that didnt smoke like this with just 1 gasket but wanted to get the cr down
2 head gaskets = bodge.
evolotion
Member #: 83
Glasgow, Scotland
im going to go with oil controll rings plugged up or too loose. does it smoke real heavy on startup after a few seconds? if so, try a cold start and keep the idle speed really low, like under 850rpm if you can. if it doesnt smoke like usual Its gotta be a piston ring issue, either bore wash , or oil controll ring tension.
I know this as I built a 1380 with weak oil control rings and it smoked proper from cold start and looked every bit as wet as your engine every time I pulled the head.
Denis O'Brien.
