| Home > Help Needed / General Tech Chat > Are these oil gallery plugs? & Under crown oil jet method? | |||||||
16 Posts Member #: 11753 Member Athens, GR |
28th May, 2018 at 09:17:38am
Hello,
Edited by nikollou on 28th May, 2018. For the love of cars!! |
28th May, 2018 at 09:31:07am
I still have this block in the garage if you need any further info |
28th May, 2018 at 09:40:56am
Hi Nic,
28th May, 2018 at 12:15:54pm
The BMW jets do have a ball and spring design in them. So in the event of an issue or low oil pressure this could help save your engine. Rather than an open hole.
29th May, 2018 at 07:57:18am
That is a fair observation Jonny, I hadn't thought of that. I do however plan to have a pretty thorough "Engine Management System" so in the event of an oil pressure loss I will have lots of bells and whistles going off to keep me from destroying my motor.
29th May, 2018 at 08:20:40am
those gallery plugs blank off the drilling that vent pressure from behind the oil pressure relif valve, theres no real " flow" through there, only what leaks past the oil reilef valve.
29th May, 2018 at 09:23:56am
On 29th May, 2018 Joe C said:
those gallery plugs blank off the drilling that vent pressure from behind the oil pressure relif valve, theres no real " flow" through there, only what leaks past the oil reilef valve. personally I leave these in place, but you clould pull them if your feeling particuarly thorough, Thanks Joe, I'll leave them in. I have enough tasks on my to-do list for now...
