Home > Help Needed / General Tech Chat > Which oil ?
minimauritius
Member #: 10545
MAURITIUS
Which oil are you using in your turbo engines ?
I've always used cheap 20w50 mineral but change it very often,
Should the turbo need synthetic ?
Don't have much choice where I live and air temperature is quite high.
jonny f
Member #: 9894
Dorking
Most here use high quality oil.
Either Millers CTV or valvoline VR1
Both 20w50
minimauritius
Member #: 10545
MAURITIUS
Wish I could buy those here and my be difficult to get them shipped...
20W50 semi-synthetic and highest possible ZDDP is basically what Miller's is, try to copy that.
For the race car with a decent gearbox and plate clutch I use Millers CTV.
For the road car I use the minispares mineral oil http://minispares.com/product/Classic/Engi...k%20to%20search
rimula diesel oil 10w40
minimauritius
Member #: 10545
MAURITIUS
I saw while searching on here you was using this shell diesel oil. This is one I can find here, it is a truck oil ?
I also found the ctv at minispares so might add this to my next order ( shipping cost more than the oil itself !)
Shell Rotella is purported to be a high zinc oil. Or just throw some of that “ZDDP in a bottle” into your engine?
jonny f
Member #: 9894
Dorking
Might be worth emailing Opie oils. I'm sure they could ship to you.
https://www.opieoils.co.uk/t-carriage.aspx#International
minimauritius
Member #: 10545
MAURITIUS
Thank you. Shipping cost are the same as minispares so will combine it on one order
