Page: |
Home > Help Needed / General Tech Chat > Help needed - engine won't rev | |||||||
209 Posts Member #: 6451 Senior Member South East Northumberland |
24th Jun, 2018 at 07:45:09pm
So, I've tried to sort the car this weekend - problem looks to be different thicknesses on the flanges of the exhaust and inlet manifolds.
30th Jun, 2018 at 01:52:44pm
So I've removed the inlet manifold and used a steel rule to ascertain how 'level' the manifold legs are - lot too bad as it turns out. I'll linnish these as level as I can anyway now it's off the car.
30th Jun, 2018 at 04:49:51pm
That's not a MAP sensor.....
1st Jul, 2018 at 09:56:21am
Rod, I called it the MAP sensor after looking at this:
1st Aug, 2018 at 01:17:19pm
Okay, so with some help I've improved the situation but not cured it totally.
1st Aug, 2018 at 06:05:59pm
You "might" be right but I would have thought the difference in sound would be obvious, or just drive it and see what MPH you get for the indicated RPM in any gear.
1st Aug, 2018 at 06:13:48pm
Thanks Rod. To my ears the car isn't going as hard as the rev limiter but I'm grasping at straws.
1st Aug, 2018 at 10:19:07pm
Jack up the front, put it on secure axle stands and "drive" it like that to compare RPM to indicated MPH.
2619 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
2nd Aug, 2018 at 08:33:12pm
Tachometer on the crank pulley to compare against the rev counter?
869 Posts Member #: 2443 Post Whore Cheshire |
4th Aug, 2018 at 09:19:15am
I had a similar issue when my supercharged mpi was first built. Weirdly it only ran shite when the bonnet was shut! After lots of messing around and thinking something was shorting electrically it turned out to be a trapped fuel hose. It was. The return hose which meant fuel pressure was way to high and it overfuelled terribly. Might be worth checking, what regulator are you running? The standard one? If so may be worth swapping that out with a known good one as well. |
18th Aug, 2018 at 04:42:58pm
Hi Andy - yes, I'm running the standard fuel regulator.
Page: |
