Home > Help Needed / General Tech Chat > 1293 Turbo build
WillCarter
Member #: 11782
Hawaii
Hi everyone, I've been directed here from TMF.
I'm starting to buy parts for a 1293 turbo build and I have so far bought:
An A+ block
10cc dished omega pistons (die-cast)
innocenti rods
GT1752 turbo
HIF44 carb
What I've decided to buy:
A cylinder head from Turbo Phil
An Avonbar phase 2 cam
I've also been told that a megajolt is good for turbo engines and an RTS clutch too (although I'm still not 100% sure what that is)
Can you help me with there rest of the parts that I'll be needing for the build, I'm new to both building engines and anything turbo so any help would be greatly appreciated!
The mini will only be for road use and I'm looking at around 130bhp, max 150bhp.
Thank you in advance for any help!
I should probably also add that I've got around £2000 to spend at the moment.
Cheers!
Will
Elfturbo
Member #: 2576
South Staffordshire
The search tool is your best mate. There is over a decade of info on here. Every aspect is covered in some detail.
HOSS
jonny f
Member #: 9894
Dorking
As Elf say, you’ll find all the info on here pretty easily.
RTS and megajolt are a good idea for a turbo mini.
WillCarter
Member #: 11782
Hawaii
Thanks both, I'll start doing some browsing!
