Home > Help Needed / General Tech Chat > Inlet to fit Fusion Fabs Manifold
WillCarter
Member #: 11782
Hawaii
What inlet manifolds have you found fit well with the fusion fabs exhaust manifold?
Cheers in advance,
Will
I think Matty has made it to allow you to use most aftermarket inlets. Contact them if you're unsure.
Phil.
WillCarter
Member #: 11782
Hawaii
That's alright then, cheers again Phil!
jonny f
Member #: 9894
Dorking
MG metro is a good choice.
Might need to lop a bit of the water way. Can’t quite remember.
steve1275
Member #: 951
Bromsgrove
I used the MG metro inlet, does need relieving on the underside. I finished up using stepped washers to get over the difference in flange thickness. Also you have to nip up the centre manifold nuts blind, using a small socket and universal joint.
'Where does the engine go?'
In terms of airflow there are better options. The Maniflow alloy inlet is excellent.
Phil.
Anthony30
Member #: 10828
Rainhill, Merseyside.
Standard metro turbo inlet? :-
On 18th Nov, 2014 D4VE said:
went down to my local hydraulics place and he gave me a suitable replacement larger nipple *smiley*
Poor flowing compared to the MG and Maniflow items.
Phil.
